Fusion Manufacture
NC Program generates unwanted circles
5 REPLIES 5
jcorral2
148 Views, 5 Replies
Good morning,
My issue happens when I export the toolpaths to a NC program. The G-code generates some big unwanted circles that does not appear on the G-code (I tried checking the lines of code manually using NCviewer), and those circles are not on the simulation too.
5 REPLIES 5
seth.madore
in reply to: jcorral2
What is your machine and post processor?
Seth Madore
jcorral2
in reply to: seth.madore
Post processor: Techno CNC (Techno CNC router)
Machine: Techno CNC LC 3024
seth.madore
Turn on "Radius Arcs" in your post dialog:
Result:
With it turned off:
Seth Madore
seth.madore
Further testing reveals the main issue; your tolerances are too loose. You're running a .004" Tolerance and .004" Smoothing Deviation, which is exceedingly large. If I set both to .0005", I get this (with Radius Arcs turned off):
Seth Madore
jcorral2
Thank you so much!!!
