Fusion Manufacture
NC program failed
5 REPLIES 5
hilmarH3628
182 Views, 5 Replies
NC program failed
Any help with this error.
5 REPLIES 5
DarthBane55
in reply to: hilmarH3628
What kind of machine are you programming for?  It says there that you used a waterjet, laser, or plasma cutting toolpath, and the post does not support those.  So if it's a milling machine, you have an operation in your setup that is not suitable.  If it is a plasma and such machine, then the post is wrong it would appear.
hilmarH3628
in reply to: DarthBane55
Hi
Thanks for quick answer, i am using dardi waterjet cutter with fagor 8035 cnc controler.
This was recomented as a start point to use fagor 8055 mill post.
How can i change that?
Best regards
Hilmar
@hilmarH3628
We don't have any fagor waterjet post in our library could you share some gcode which works fine with your machine so we can suggest some generic post which can be used to post
Boopathi Sivakumar
Senior Technology Consultant
hilmarH3628
M73 water on
M75 Abrassive on
M76 Abrassive off
M74 Water off.
