Fusion Manufacture
Nc form
7 REPLIES 7
Message 1 of 8
Emre_Yucel
225 Views, 7 Replies
Nc form
The glass programmes made in the Fusion360 programme are given to the operators by the operator himself by writing on a piece of paper.
In this case, the risk of making mistakes is very high. The wrong programme can be called or the operator can write the wrong programme.
In order to prevent these mistakes, Cam programmes create an automatic NC Form.
This form contains information such as programme number, tool name and length, the holder to which the tool is connected, speed, feed, machining times.
It is done in WorkNc programme, is it possible to do it in Fusion?
Thanks for your help in advance, good day
7 REPLIES 7
Message 2 of 8
seth.madore
in reply to: Emre_Yucel
Are you asking if Fusion is capable of creating Setup Sheets? The answer to that is; yes, most definitely.
We have built in Setup Sheets as well as the ability to use a post processor that generates an Excel based Setup Sheet. I'm particularly fond of that one, as it allows for greater customization as to what data is being recorded.
Seth Madore
Message 3 of 8
Emre_Yucel
in reply to: seth.madore
Hi seth, thank you very much for your feedback I appreciate it, so can you help me how to do it can be video or demo thank you very much for your help, good day
Message 4 of 8
seth.madore
Certainly, here are the three methods with all different results in the output, all depends on how much you want to see:
Seth Madore
Message 5 of 8
Emre_Yucel
Hi Seth, thank you for sharing the video, I can't view the video, for your information, have a nice day again, thanks
Message 6 of 8
the video is now processed and up.
Please click "Accept Solution" if what I wrote solved your issue!
Message 7 of 8
Emre_Yucel
Hello Seth,
I have one more question, can we edit the NC form, for example to add or remove information, I am grateful for your help, thanks
Message 8 of 8
seth.madore
Only on the Excel based Setup Sheet. It will require editing of both the Excel sheet and the .cps post processor. This isn't an area I can advise in, I would suggest working with an Autodesk partner to accomplish this.
Seth Madore
