Announcements
Nakamura Tome TW10MM, Fanuc 18iT controller - what post should I use?
internalmecanix
internalmecanix
Hi!
I have a Nakamura Tome TW10MM (live tools, Y-axis and C-axis). I am wondering what post to use? Should I use the Nakamura Tome mill turn post or is that to new for my machine? I don't have a swivel B-axis, only C AND Y. Any suggestions? Would a fanuc post work for normal lathe functions? How should I think about this problem and what can I try?
Thanks!
James
seth.madore
Have you tried the Nakamura post? It's been around for as long as I can remember (at least 6-7 years), so it's not technically "new".
Seth Madore
internalmecanix
Hi Seth,
many thanks for the reply. I am trying the Nakamura post now. G-code looks mostly ok. I don't have B axis or V axis (not sure what V axis is) for for now I will edit the post by hand and set the turret home moves to:
G00 G28 U0. W0.
instead of:
G00 G28 U0. V0.
G30 W0.
many thanks!
internalmecanix
Hi Seth,
I tried out the post. It does not work. I don't think it is far out but definitely not working. I have no experience with modifying posts and am in a hurry to make parts. Can I buy a post for this machine or can someone help me and I work with them to fix it?
Many thanks! James
the nakamura post works. I use it on a AS200L with y,live tooling and subspindle.  There is a couples modifications to do if you want to get it rigth for your methods and mahine but 90% work properly direct from the post.
v and w are the incremental mode of x and y moves.
https://www.youtube.com/watch?v=v5rp1ydlvT4&ab_channel=TimLaRiviere
Hi Alexandre,
many thanks for your reply. After many diversions I am now using the machine.
cheers!
