My Model is not connected
georgeENF84
georgeENF84
I received a model of a part to machine, I was setting up a tool path when it gave me this error message ...
Error: Turning profile is split into two or more closed parts. You can avoid this error by modifying your model to ensure all parts of the profile are connected., I received two models from this customer one worked fine this one did not, my question is how do I connect the parts in this model so I can machine it ..... Thank you ,George 🙂
engineguy
@georgeENF84
Can you please upload the non working model, it does sound as though the sender didn`t join the parts together, have you tried using the "Combine" function in the Design mode ??
To upload got to :_
File > Export > Select f3d format > Save to a location on your computer > Then use the "Attachments" facility below the box where you type a reply
seth.madore
It sounds like you need to turn on "Spun Profile" in the Setup:
Seth Madore
georgeENF84
Attached you will find the model
seth.madore
Yep, Spun Profile does the trick:
Seth Madore
georgeENF84
Yes that took care of the error, Thank you very much 🙂
