Fusion Manufacture
My CAM setups are vanishing into thin air
3 REPLIES 3
scacob
115 Views, 3 Replies
The entire setup section of my manufacturing browser is gone from some files where I had saver operations.
This is on a Windows 10 machine.   It has happened in multiple files.   Has anyone else seen this issue?   setupmissing.PNG
3 REPLIES 3
seth.madore
in reply to: scacob
That's odd, to say the least. What happens if you minimize Fusion? What happens if you restart your computer? Does it persist thru open and close of those same files?
Seth Madore
scacob
in reply to: seth.madore
@seth.madore rebooting the computer didn't change the situation at all.
One thing I noticed is when opening the file it gave me an "errors were encountered while downloading the file" and it didn't open the file.   If I try a second time it does open the file but again there is no setup.  Perhaps the file is corrupted in some way but I have at least 2 of these files with this behavior.  Both were last saved yesterday. 1/21/23
Interestingly if I create a new setup it also does not show but if I create a new operation and go to set a tool for that operation I can see the setups in the list.   See image below yet none show in the browser.
scacob
in reply to: scacob
@seth.madore I am pretty confident both of these files somehow got corrupted yesterday.   I went back the earliest version and it seems to be ok.  Lost a little bit of work but the setup at least shows normally.
