Announcements
MULTIPLE WORK OFFSETS NOT POSTING CORRECTLY
Although set correctly multiple work offsets doesnt post in tool order. and posts one setup at a time instead of ordered by tool. nc program (fusion feature flag item) also seems to be affected. as the displayed program doesnt post as intended.
Replies (10)
seth.madore
I am not seeing that behavior on my end. Are you on PC or Mac?
I'm seeing correct behavior; Set it to "Order by Operation" and it gives me code as expected....
T7M6(1.50 X .062 SAW)
G0G90G54X-1.1981Y.688S750M3
G0G43H7Z.1M8T1
G1Z-.251F20.
G41D7Y.638
G3X-1.1481Y.588I.05
G1X.118F3.
X1.1481
G3X1.1981Y.638J.05F20.
G1G40Y.688
G0Z.1
M9
G49
G53Z0.M19
G0G90G55X-1.1981Y.688S750M3
G0H7Z.1M8T1
G1Z-.251F20.
G41D7Y.638
G3X-1.1481Y.588I.05
G1X.118F3.
X1.1481
G1G40Y.688
G0Z.1
M9
G49
G53Z0.M19
G0G90G56X-1.1981Y.688S750M3
G0H7Z.1M8T1
G1Z-.251F20.
G41D7Y.638
G3X-1.1481Y.588I.05
G1X.118F3.
X1.1481
G1G40Y.688
G0Z.1
Seth Madore
more complex multiple tool setups. will not post order by tool. g54,55,56,57 tool t1 t2 t3 post ordered as follows. g54 t1 t2 t3, g55 t1 t2 t3, g56 t1 t2 t3, g57 t1 t2 t3. old behavior was g54 t1 g55 t1 g56 t1 g67 t1, g54 t2 g55 t2,ect ect
seth.madore
Are you on Mac or PC?
Can you share your file so I can see your exact settings?
What post processor are you using?
Do you have any Feature Flags or Beta Mode turned on? If so, have you turned them off?
Seth Madore
im on windows. i haven't changed settings back yet. i do have some feature flags on. behavior worked as expected before the update.
seth.madore
You have two tools labeled with the same number. Moving them to sequential allows it to post out as expected.
Seth Madore
my post, posts out tool by name. to my understanding. the tool number is not used?
seth.madore
The post processor needs to process the tools in the order they are programmed. If you have duplicate numbers, it's quite likely that is the issue. I can certainly raise an inquiry to see if this is set in stone. My suspicion is that "yes" the numbers matter
Seth Madore
initially seeming to be correct. i checked a file that had the correct output in the "nc programs" "order by tool" that had the expected output prior to the update. re numbering the tools and re generating all operations. i seem to have the same behavior as described previously even with all different tool numbers. see attached. i understand this feature is beta. but something would appear to have changed. See attached file with issue. and photo of tedious work around.
Any thoughts on my last post^^  it did work before the update. . .
cj.abraham
@Anonymous  The NC Programs feature is not ready yet, hence why it is behind a feature flag. The setup and post process dialog were not changed (and relies on tool number to correctly order patterns, that is being changed to tool instance). I was able to achieve the correct result with your test files and post by making sure that each tool instance had a unique tool number (renumber tools). The result was 3 Face operations, then 3 2D Contour 1, followed by 2D Contour 2.
