Multiple WCS not posting properly
NickErmis
NickErmis
I have a project with 8 setups and using only 6 tools.  When I post it is posting all of G54, then G55, then G56.. etc, not arranging by tool.  I am sure I am missing something on my setup, just not sure what.  There are 4 unique parts that I did in 8 setups (2 each).  I didn't make multiple wcs for each part because I want my origin to be set off the fixed jaw.
I am using the Haas next generation post and have reorder to reorder to minimize tool changes.
Also, Is there any way to change the WCS occurrences to 2, but have it flip the part so that it automatically picks up off the fixed jaw?
Thanks in advance,
Nick
Hi @NickErmis , have you tried create NC program? In the operation tab there is the option to reorder.
To get WCS to change by 2 you edit it in the setup.
NickErmis
That is too easy!! thank you.
is there any way to mirror or rotate additional wcs offset?
If you are wanting to flip the part and machine the other side, I would make another setup with the part orientation and WCS location needed. There is also the add pattern option.
