Fusion Manufacture
Multiple depth passes with Four axis
2 REPLIES 2
zigzag2015
142 Views, 2 Replies
I am a very recent convert to Machining Extensions and have some basic questions.
I have got some good fourth axis rotary toolpaths but the tool path goes to full depth, the finished size, in one pass.
What I would like to do is use two or three passes at increasing radial depth and cut 'layers' off the rotating stock.Is this possible?
Craig
2 REPLIES 2
a.laasW8M6T
in reply to: zigzag2015
Go to preferences and turn on the rotary pocket preview:
Then use the Rotary pocket toolpath to rough the part:
You can then finish with the Rotary toolpath.
If you want to upload your file here we may be able to offer some more suggestions
zigzag2015
in reply to: a.laasW8M6T
thanks have tried that out and it works a treat, thanks again.
Craig
