Multiple assembly's therefore multiple setups - Folder feature please!
- Mute
- Permalink
- Report
Hello Fusion team,
I have a request/suggestion and I think I wont be the only one that will appreciate it.
I am currently working in a file where I have 10 different assembly's - its a jig fixture for a 4th axis machine, uses the same base and then there are 10 different products being milled on this fixture that has therefore 10 different jigs that can go on top of it. Since its all modeled in one file - multiple assembly's, each assembly is about 6 to 12 different parts. When I got to Manufacture I'm going to get a little lost ![]()
So I take part 1 from assembly one, create a setup, do the CAM work on one side of that part, create setup 2 for the other side and so on... once I'm done with assembly 1, I have 5 setups, and I go to assembly 2, and so on... well my suggestion/request is, can you put a feature in so I can group the different setups according to their assembly's - Folders.
Folder 1 - Setups 1 through 5 - I can name that folder whatever my assembly ones part number is and so on.
This way I wont have 50 different setups one after another and then click away till I find the one I need if I am remaking one of the parts.
I hope you understood what I mean.
br,
kajick
Fusion
