Fusion Manufacture
Multicam post processor running with an inverted z axis
2 REPLIES 2
danielYZ38R
131 Views, 2 Replies
I am running the newest post processor released for multicam routers, MultiCam Iso / multicam, and it seems that the machine wants to run at the top of the z travel and in reverse, i.e. the spindle drops lower for rapid moves. I have tried the main fix I've seen in these forums
var zFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-1});
with scale:-1 removed the tool path runs upside down, but when i add the scale:-1 the program fails to cut. the spindle starts spinning, moves to the correct spot then fails out.
Any help would be great.
2 REPLIES 2
Warmingup1953
in reply to: danielYZ38R
Multicam Australia? Edit: Ignore that I see it's a Multicam 3000
engineguy
@danielYZ38R
Can you upload a sample Fusion f3d file and also a copy of the Post Processor that you are using.
File > Export > Select f3d Format > Save to a location on your Computer > Then attach to your reply
