Fusion Manufacture
Multi-Axis Contour refuses to follow the chain, follows edge instead
4 REPLIES 4
Bradley_West_
146 Views, 4 Replies
I am trying to use an endmill to generate 45deg chamfer using multi axis contour. Selecting an edge to form an open chain is generating a path as expected. However - when trying to set an extension length to -8, to pull the cutter up short of the end of the feature it is ignoring the chain and instead running the length of the selected contour causing a gouge.
Any ideas?
4 REPLIES 4
a.laasW8M6T
in reply to: Bradley_West_
 can replicate this behavior, I'm not sure if its intended but could be a bug, @seth.madore  can confirm if this is intended behavior?
You can use the Tangential fragment extension in passes tab, but this shortens both ends of the contour which I don't think you want.
A workaround is to split the faces adjacent to the contour to allow a shorter chain selection
See attached for an example of that
seth.madore
Thanks for raising this issue, both of you. I've logged CAM-51559 to investigate this.
Seth Madore
Hi @Bradley_West_
Thanks for feedback. Please use the following workaround until the problem is fixed. Unfortunatelly it applies to both ends of the selected curve.
Oleg Tikhomirov
Software Engineer
@oleg.tikhomirov Thanks for the work around!
