Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Multi-Axis Contour - how to do this operation?
7 REPLIES 7
Message 1 of 8
jambrozy
310 Views, 7 Replies
I have problem with generate toolpath on inside diameter. I want to mill from top to bottom with line what I drowe. Anyone explain how can I do that? I have a manufacturing extension.
Tags (1)
Labels (3)
7 REPLIES 7
Message 2 of 8
seth.madore
in reply to: jambrozy
It might be easier if you shared your Fusion file here, could you do that?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
What tooling are you using, and what's the dimensional characteristics of this feature (functional, accurate, both, etc.)
Seth Madore
Message 3 of 8
jambrozy
Okey, some update, i generate toolpath with geodesic strategy but is some problem with simulation, fusion get close ...
 Anyone can help where I do something wrong? ;o
Message 4 of 8
jambrozy
@seth.madore  thanks for quick answer.
I need to mill radius 2.5 so I used mill ball fi 5 and I want only mill from top to bottom a few times. I create geodesic toolpath and I thing it looks good. But something wrong is with simulation, i need to check this on my second computer at home.
In attachment I send .f3d file.
Message 5 of 8
seth.madore
Hmm. Simulates just fine on my PC. Are you PC or Mac? Win10 or 11? Are your video card drivers up to date?
Seth Madore
Message 6 of 8
jambrozy
I found graphics drivers need to update ... give me a few minuts 🙂 You've got some idea how can I do this with only one toolpath?
My computer with RTX 3070 TI:
Message 7 of 8
jambrozy
Ok... update drivers helped, now everythings works great :)) Can you explain @seth.madore , to do milling in example which we have here, geodesic is good option?
Message 8 of 8
jambrozy
Okey, sorry but I used geodesic strategy for the first time and it's great... 🙂 I marked only "limit number of stepovers" and everything is how I want.
 I've got what I want 🙂
Technology Administrators
