Fusion Manufacture
MR-1 Tool Path won't cut all of the cavity
1 REPLY 1
hidani_tim
99 Views, 1 Reply
I am trying to cut injection mold cavities in an aluminum block, but when I make a tool path it does not make it to the top edge of the cavity. Seems to get better with a smaller bit, but still does not cut all the way up. I have been using the "parallel" cutting path. Initially I though the gap was the diameter of the tool, but after running the path the top edge is not being cut. I am wondering if an alternative cutting path or changing a limit would allow the tool to travel to the top edge without cutting it
1 REPLY 1
a.laasW8M6T
in reply to: hidani_tim
Hi
There are several setting/selections that could be causing this problem, but without seeing the file its ard to tell what the problem is.
Could you share the file here? Goto File>export>Save as .f3d/.f3z
Also parallel is not the best toolpath for that sort of shape, you would be better to use Flow, Blend or Geodesic.
