Fusion Manufacture
Moving spindle stop to Z retract line Doosan VMC post
5 REPLIES 5
infoTS4YA
174 Views, 5 Replies
I've recently switched my Machine shop from using Edgecam to Fusion360 and I'm currently adjusting posts to get programs formatted in a way that is somewhat similar to the rest of our NC programs. We run mainly Doosan machine tools with Fanuc Controllers.
One thing I've noticed in the programs that Fusion outputs, is that code is separated into a lot of different lines when the machines would run more efficiently if they were compressed, I need some advice on modifying my post processor on how to overcome this.
The current issue I have is I want the machine spindle to be turned off on the Z retract line e.g.
Like this
G0G91G28Z0.M5
This will stop the machine having to Wait for the spindle to slow down as it should do most of it during the retract, it would also be helpful to get the M9  onto the same line.
Below is a picture of the Post Script. Thanks
5 REPLIES 5
ltomuta
in reply to: infoTS4YA
Click on line 49 in that debuggedfile.NC. It will show you which line of code from the post generated that block sequence. If the code does not seem relevant, click again to cycle through function calls.
Once you figure out where the code to go home on Z is generated add there a call to stop the spindle. I.e. the code that generated the 53 line from that file.
Once you have that done and tested you can figure out how to put the M05 in the same block instead of a separate one if you really want that.
infoTS4YA
in reply to: ltomuta
Thanks for your reply ltomuta,
"you can figure out how to put the M05 in the same block instead of a separate one" This is what I don't know how to do, how do you get the code to output on the same line?
Moving the section of "spindle off" code up on the same line as the G28/G30 line in the post doesn't move it in the posted NC file.
ltomuta
Without having your actual file to quote exactly, what you are looking for is a writeBlock() function which it turn has several parameters that generate the G0 if needed, the G91, ...
Something like
writeBlock(gMotionModal.format(0), gFormat.format(91), gFormat.format(28),  zFormat.format(0) );
To put an M05 there the simple answer is that you add another parameter
 writeBlock(gMotionModal.format(0), gFormat.format(91), gFormat.format(28),  zFormat.format(0), mFormat.format(5) );
The complicated answer is that the new parameters should be more like
 mFormat.format(getCode("STOP_SPINDLE", SPINDLE_MAIN))
To complicate it further, you should stop the active spindle, whichever it may be so ...
Now, once you figure out which M command you give and you put it on the correct line you are still left with a problem. Previously the spindle stop was done by calling
onCommand(COMMAND_STOP_SPINDLE);
Now you will have to cancel that call, since the spindle is already stopped, but you will have to do everything that function call used to do aside from issuing the M0x, i.e .you also have to do something like
machineState.mainSpindleIsActive = false;
sOutput.reset();
Or maybe you can still let the onCommand call in place, just make sure it does not output anything, just sets the machine state.
infoTS4YA
OK I got it, I have to put the code to stop the spindle in the "safe retract" sub section of the post and not the "tool call" sub section for it to output on the same line.
I think I'll leave it as it as as to not end up with conflicts down the road. Thanks for you help.
RG_Productions
Hi, looking to implement this in our post. What would be the correct way to go about this? Cheers
