Any plans on improving direction control with the spiral toolpath?
Making Spiral perform a facing operation that Rob Lockwood demonstrated a while back is finicky 99% of the time.
Something simple like this either takes 5 minutes of playing around or luck that some setting doesn't interfere with another:
Getting it to face off a part is easy but getting it to face off a part without plunging into the stock or conventional milling is not.
"Clockwise" checkbox, link from "out-in", "oneway/other way" all seem to either not make any change, or randomly interfere with another setting.
Took me 10 minutes to find the right combination on 2 facing operations (because it's so finicky) and now for the 3rd of 4th it's impossible. Tried everything, won't do it. Just not doing what I tell it to and not doing what I tell it not to do (because sometimes that works).
Identical feature: Same settings, different settings; either the tool is conventional milling or it's plunging into the stock.
Sometimes it won't work so I'll change something > still won't work > change setting back > it works.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
