Fusion Manufacture
Mori Seiki post
3 REPLIES 3
lucaJUH7Z
119 Views, 3 Replies
Mori Seiki post
Gday
         When i post the G code on Mori Sieki NLX mill/Turn (no other post work with my machine) after i have altered the part but not the stock does it alter the position of Z, eg instead of the datum being at the front, it is changed to the back of the part.
        Gareth
3 REPLIES 3
seth.madore
in reply to: lucaJUH7Z
Is this the same issue as you've raised in your other post, or something different?
Seth Madore
lucaJUH7Z
in reply to: seth.madore
Thank you for your reply
          I am not sure if they are related in regards to the way i am do the setup or there is a glitch in Fusion 360 which doesn't like the Mori Seiki setup.
           I have attached the drawing for a better explanation, All i do is change the angle blades but the stock stays the same but once i do that everything changes with the setup and the program.
          I use a mill tool on a live tool to cut the blades out on a lathe CNC.
seth.madore
Please share your file here, so we can better advise you:
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
