Modify post processor to support Manual NC Pass Through
SGoldthwaite
SGoldthwaite
I'm using the shopbot post processor (https://cam.autodesk.com/hsmposts  ver 43779).  I followed the instructions in this article (www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/post-processor-manual-NC-n... and added the following code to the post processor:
// Manual NC PassThrough - added by SRG 4/30/22
function onPassThrough(text) {
  writeComment("Manual NC Passthrough");
  var commands = String(text).split(",");
  for (text in commands) {
    writeBlock(commands[text]);
In Fusion, I'm using Manual NC > Pass Through and adding this (I'm only testing):
The post processor is outputting this:
' Manual NC Passthrough
JX
 -10
JY
 5
I want it to output this:
JX, -10
JY, 5
Can anyone tell me how to edit my post processor to do this?
yd_kwon
Try it with the code below
  var commands = String(text).split("\n");
This code doesn't break the text with a comma (,), it breaks the text based on the line break.
JX, -10
JY, 5
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
SGoldthwaite
That worked, thanks!   It does write the comment multiple times like this:
JX, -10
JY, 5
It's doesn't hurt anything, but do you know how to get "Manual NC Passthrough" to print only once?
yd_kwon
That's not possible.
The onPassThrough() function is repeated for each object of text entered. This can be verified by using a dumper post file.
There are two alternatives.
1. include the desired comment text in the text. Like below
JX, -10
JY, 5
2. use the manual NC-comment with a preceding line.
Before PowerMILL
SGoldthwaite
Thanks.  That's a good idea to put the comment in the in with the pass-through code instead of the post processor
