Fusion Manufacture
Modify post process default no "Preload tool"
1 REPLY 1
ea425019
75 Views, 1 Reply
I am running a Centroid Acorn6 presently with the provided post processor (autodesk one).  It defaults to Preload tool, this causes occasional errors in ATC selection, as my rack system has no need for it.  The errors are occasional, but still a rather big deal.
I can unclick the box, but I work thru a lot of fast posts, I need this one to default to "off", it seems to offer no such functionality.  I modifed the post by commenting out the preload tool commands, as shown in the snip, but it still adds a T# on the line after a toolchange.
If I unclick the box it does not, which is good.
Also, for naming the file, to "1001" by default, can we set up fusion to use a date/timecode. I prefer that, it saves me time.
1 REPLY 1
seth.madore
in reply to: ea425019
Set this to false:
that said, your NC Program/Post workflow should be remembering your selection for that post. Are you using a Machine Configuration, by chance?
Seth Madore
