Fusion Manufacture
Model won't center in stock
2 REPLIES 2
chrisevrard
104 Views, 2 Replies
Hey All,
I cam'd my part up last night and everything looked good. This morning I imported some soft jaws and moved my part around a bit. Now it seems I cannot get my part centered in my .875 diameter stock. One edge sticks out of the stock no matter what I have tried.
I don't know what I did that would have caused this. Any ideas?
File attached
Thank you,
Chris E.
2 REPLIES 2
seth.madore
in reply to: chrisevrard
Dragging parts around in design is always a risky proposition. You have a couple options:
1) Just model your stock in Design (using proper constraints and joints to the model) and select that in MFG as your Stock
2) create a sketch and an axis that gives you something to select for the normal method of stock definition
Seth Madore
chrisevrard
in reply to: seth.madore
Modeling the stock worked. Thanks Seth!
That is going in the "tricks" box.
Best,
