Fusion Manufacture
mitsubishi tapping
11 REPLIES 11
Message 1 of 12
emre_sahin9PU3F
226 Views, 11 Replies
mitsubishi tapping
After executing the tapping program, R1 code appears in the nc line. The machine gives an error in this code. How can I block the R1 code?R1.png
11 REPLIES 11
Message 2 of 12
Does it need any "R" value there, or should it be scrubbed entirely?
Seth Madore
Message 3 of 12
If it's to be scrubbed entirely, you can just comment out this section at line 423:
case "tapping":
      F = tool.getThreadPitch() * rpmFormat.getResultingValue(spindleSpeed);
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 84),
        getCommonCycle(x, y, z, cycle.retract),
        "P" + milliFormat.format(P),
        (getProperty("useRigidTapping") != "no") ? pitchOutput.format(tool.getThreadPitch()) : feedOutput.format(F),
        conditional((getProperty("useRigidTapping") == "without"), sOutput.format(spindleSpeed)),
        //rigidTapFormat.format((getProperty("useRigidTapping") != "no") ? 1 : 0)//
(Note the "//" before and after this "rigidTapFormat" section.
Seth Madore
Message 4 of 12
I'm trying to load the post after closing the lines. It gives invalid postprocessor error.
Message 5 of 12
must be completely cleaned.
Message 6 of 12
Here you go, I modified your post, give it a try!
Seth Madore
Message 7 of 12
Message 8 of 12
Can you upload the post you sent to your own fusion program and receive posts?
Message 9 of 12
Would you be so kind as to translate what those error messages are into English?
All I did was take your file and comment out that section. I was able to use it in Fusion and got this for code:
N55 G00 X0.4921 Y0.7874
N60 G43 Z0.1 H01
N65 G98 G84 X0.4921 Y0.7874 Z-0.876 R0.01 P0 F0.05
N70 G80
N75 G00 Z0.1
N80 M09
N85 G28 G91 Z0.
N90 G90
N95 G28 G91 Y0.
N100 G90
Seth Madore
Message 10 of 12
AdamKunzo
in reply to: emre_sahin9PU3F
syntax error line 423, I fixed this 🙂
Message 11 of 12
Wonderful. Thank you for the help 🙂
Message 12 of 12
There was a problem yesterday. I couldn't understand why. There was no problem with the post sent by Adam Kunzo. Thank you for your support.
