Fusion Manufacture
Mitsubishi A500
2 REPLIES 2
spano.dom
110 Views, 2 Replies
Mitsubishi A500
We just acquired an older cnc machine which is an intertech 41-470 with a Mitsubishi a500 controller. The gang turret is an X,Y,Z where in the Y moves the tools up and down. I see that fusion has a post processor for Mitsubishi but the output is a bit different just outputs x and z.
Is there anyway to get a post processor for this type of machine or will the post just work?
2 REPLIES 2
seth.madore
in reply to: spano.dom
It's doubtful that the post will "just work", as it's a post for a 2 axis lathe. Do you have any sample code that may have come with the machine? It's likely that a Fanuc could do the job, but it's likely going to need some edits
Seth Madore
spano.dom
yeah so a couple things I found out were that it doesn't like I J K method for radius's so I enabled use radius arc and have to put in the Y so that the tool changer can bring everything back home. Also it doesnt use say t0101, just uses t1.
Heres a snip bit of code
O0001
G90 G95 G18
G20
G92 S6000
G53 G0 X0.
G53 G0 Y0.
G53 G0 Z0.
(FACE ROUGH)
T2
G90 G95 G18
G54
M8
G97 S1600 M3
G0 X0.45 Z0.2369
G0 Z0.01
X0.35
G1 X0.25 F0.008
X-0.0312
G0 X0.45
Z0.2369
(ROUGH PROFILE)
G97 S1600 M3
G0 X0.35 Z0.2369
Z0.0734
G1 Z0.02 F0.008
X0.0938
Z0.
X0.0987 Z-0.0025
G3 X0.1137 Z-0.0206 R0.0256
G1 Z-0.0598
X0.117 Z-0.0611
X0.12 Z-0.0625
X0.13 Z-0.0675
G3 X0.145 Z-0.0856 R0.0256
G1 Z-0.4656
X0.25
X0.305
G0 X0.35
Z0.2369
M9
G53 G0 X0.
G53 G0 Y0.
G53 G0 Z0.
(FACE FINISH)
M1
T3
G90 G95 G18
G54
M8
G97 S1500 M3
G0 X0.45 Z0.2369
G0 Z0.
X0.35
G1 X0.25 F0.0025
X-0.0314
G0 X0.45
Z0.2369
(FINISH PROFILE)
G0 X0.35 Z0.2369
X0.0516
Z0.0996
G1 Z0. F0.0025
X0.0523
G3 X0.0746 Z-0.0046 R0.0157
G1 X0.0846 Z-0.0096
G3 X0.0937 Z-0.0207 R0.0157
G1 Z-0.0658
X0.0981 Z-0.0668
X0.1022 Z-0.068
X0.1058 Z-0.0696
X0.1158 Z-0.0746
G3 X0.125 Z-0.0857 R0.0157
G1 Z-0.4657
X0.285
G0 X0.35
Z0.2369
M9
G53 G0 X0.
G53 G0 Z0.
(FRONT SHOULDER)
M1
T4
G90 G95 G18
G54
M8
G97 S1600 M3
G0 X0.35 Z0.2369
G0 Z-0.065
G1 X0.0937 F0.00157
X0.35
G0 Z0.2369
(.02 GROOVE)
G0 X0.35 Z0.2369
Z-0.395
G1 X0.074 F0.00157
X0.35
G0 Z0.2369
M9
G53 G0 X0.
G53 G0 Y0.
G53 G0 Z0.
(PART)
M1
T5
G90 G95 G18
G54
M8
G97 S500 M3
G0 X0.35 Z0.2369
G0 Z-0.568
G1 X0.051 F0.0025
X0.35
G0 Z-0.4318
G1 X0.0963 Z-0.5586 F0.0025
G3 X0.051 Z-0.568 R0.032
G1 X-0.064
X0.35
G0 Z0.2369
M9
G53 G0 X0.
G53 G0 Y0.
G53 G0 Z0.
M30
