Mistake in 2D Contour operation
100899Wot
100899Wot
I can’t create operation with the plunge angle in the depth steps to be as in the parameter "Ramp". Steps after a first stay at an angle of 2 degrees, but i need 30. I tried edit many options without result, i think this is a program mistake. Thank you for attention.
DarthBane55
Change the  "maximum ramp stepdown".  I put it to 200 and it worked.  This parameter works in conjunction with the ramping angle, whichever is smaller, that is what it does.  So at 20mm you were limiting the angle.  To avoid that, you put a really big number in the max. ramp stepdown to make sure this won't limit your angle.
