Misprints in CAM popup help
copypastestd
Message 1 of 11
copypastestd
Hi, right now I am learning CAM hard.
So I read help about all features.
Where I can write about the misprints and other errors?
There is an example:
Replies (10)
Message 2 of 11
jeff.pek
Wow, someone even more nitpicky than I am! 🙂
Thanks for the eagle eye. Please feel free to report them here; we'll work on knocking them out.
Jeff
Message 3 of 11
jeff.pek
CAM-7517
Message 4 of 11
copypastestd
Another thing that is really annoying - is 1 sec popup help window.
What I mean. Frankly, I understand where is the problem only today.
So, when I used PC with big screen - I almost didn't notice that problem.
But when I use 14'' laptop, it happend all the time. If I keep cursor on some feature with large help window, that window just appear only for one second.
And If I do not quite understand what that feature do, I have to go to the manual page through browser and seach that description there.
But if I move strategy window to the bottom of screen - that help window fit on the screen and do not go away.
There are two screencast for illustration:
http://autode.sk/2qZ6fFU
http://autode.sk/2sxhS91
Message 5 of 11
jeff.pek
If there are specific parameters that are exhibiting that, please call them out here.
  Jeff
Message 6 of 11
copypastestd
That problem with some parameters with large help popup window.
There are on my screencasts:
On my screencasts it's a Passes > Direction and Passes > Tolerance and Passes > Stock to Leave > Axial Stock to Leave (for Face strategy).
But the same problems will be for all other strategies, with same parameters.
Another "bad" parameters, with same behaviour:
Heights > Retract Heights > From
Heights > Feed Heights > From
Heights > Top Heights > From
Heights > Bottom Heights > From
Passes > Smoothing
Passes > Minimum cutting radius
Linking > Ramp > Ramp Type
It is not full list, such problem parameters about several dozens.
Message 7 of 11
jeff.pek
Got it. Thank you. I can reproduce by taking my display resolution down low enough.
  Jeff
Message 8 of 11
Steinwerks
@jeff.pek how about this one?
https://forums.autodesk.com/t5/hsm-ideas/implement-parameters-with-shift-key-in-fusion-360-tool-libr...
Don't know if it's an oversight or bug but needs to be there IMO.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 9 of 11
jeff.pek
That's a good one. I've voted it up.
  jeff
Message 10 of 11
copypastestd
As I understood, problems with popup windows which orientated only to the top. An when it don't have enough room - it disappeared.
But some of windows works fine, they are reorientated to other sides (right, left, bottom) - to fit on the screen.
http://autode.sk/2rwdf0i
Clearance Height works fine for example.
Message 11 of 11
jeff.pek
Reported as UP-35111.
