Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Mismatch caused by Horizontal
3 REPLIES 3
Ryan_Fab
337 Views, 3 Replies
Morning all,
Can someone help me out with this? Am i missing something obvious that I shouldn't be!?
The file is attached but as you can see from the image I'm not getting the results I want. It looks to be the horizontal causing this rather than the parallel finishing early
TIA
3 REPLIES 3
HughesTooling
in reply to: Ryan_Fab
Have you cut a part and does it show? Looking in NC Corrector it looks OK the horizontal path is at -19.0 and the parallel is also at -19. There is some deviation in the parallel as you've used smoothing but very small.
You can see some of the toolpaths below are arc moves that go into the part. Disabling smoothing fixes that but the amount will be less than the smoothing tolerance.
Mark
Mark Hughes
Owner, Hughes Tooling
Ryan_Fab
in reply to: HughesTooling
Hi Mark, thanks for taking a look. I havent yet, Im still awaiting material. I was hopeful it might something graphics related. Ill cut one and let you know the results
cheers
Ryan_Fab
Hi Mark, bit of an update for you, I ran the part and it cut fine, no step at all. It looks like it was a graphic error
Cheers
