Fusion Manufacture
Mirrors engraving when using CX Help please
4 REPLIES 4
P1TechKWRCJ
151 Views, 4 Replies
I am having problems engraving the part number on the face of the pieces I am making. I am running the parts on a Doosan 2600 Puma SYII.  I originally had  fusion posting to engrave with the default XY moves but when doing so we discovered a alignment issue with the Y axis so it only did 3/4 of the part number. But with the exception of the C location being off for some reason the engraving  itself worked okay. I  then tried to force it to post to cut with XC by doing a manual NC with action selected and useXZCMode in the action box. this fixed the issue i was having before by keeping Y in the same location but it mirrored the engraving. For the engraving I am using a trace tool path. Also when I run the simulation everything looks correct and the C axis locations that it is giving when posting look reasonable. If someone could tell me what I have done incorrect I would greatly appreciate it.
4 REPLIES 4
seth.madore
in reply to: P1TechKWRCJ
Is this on the main or sub spindle?
If it's on the sub spindle, there's a checkbox in the post properties to reverse the AC axis, I find that for my own Lynx, that box needs to be ticked.
Seth Madore
P1TechKWRCJ
This is on the sub spindle and I do have that box checked.
seth.madore
What do you get if you uncheck it?
Seth Madore
P1TechKWRCJ
That was the problem thank you
