Fusion Manufacture
MillTurn Setup -> hasGlobalParameter("autodesk cam:fixture-path") is FALSE
2 REPLIES 2
martini_ewald
80 Views, 2 Replies
Ciao Guys,
my post use the
 if (hasGlobalParameter("autodeskcam:fixture-path")) {
        fixturePath = getGlobalParameter("autodeskcam:fixture-path");
to export the fixture as STL. In a MILL Setup it works well, but on a MILLTURN setup, nope. It seems to be a FUSION 360 option that is not available on MILLTURN setup - WHY is it so?
2 REPLIES 2
seth.madore
in reply to: martini_ewald
Hmm, it should be working. Do you have  this set where your other post variables are?:
exportFixture = true;
Seth Madore
martini_ewald
in reply to: seth.madore
Yes - the settings are all rhight - if the CAM SETUP is a MILL setup, it works. Only in a MillTurn Setup the fixture is always null.
