Fusion Manufacture
Milling round pocket generates a flat bottom
4 REPLIES 4
paulericFEV2X
167 Views, 4 Replies
I have 15.875 radius open pocket I need to mill, and after doing a 3D Pocket clearance with a 1/4" bit and a 3D Countour with a 1/2" Ball nose bit, I end up with a flat bottom.
I tried about 50 permutations of settings and can't get it right.
Here are my last settings for the 3D Pocket Clearing
paulericFEV2X_8-1710547356560.pngpaulericFEV2X_1-1710547127346.pngpaulericFEV2X_7-1710547329545.png
And my settings for my 3D Contour
paulericFEV2X_3-1710547223135.pngpaulericFEV2X_4-1710547238987.pngpaulericFEV2X_5-1710547259787.png
Any idea how to get rid of it?
Labels (3)
4 REPLIES 4
seth.madore
in reply to: paulericFEV2X
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
seth.madore
If possible, I would suggest a different toolpath, such as Parallel, Blend, Geodesic or Flow. Contour in this case is not always the best choice
Seth Madore
Geodesic worked great! Thank you Seth.
seth.madore
It's such a simple toolpath to define and the results are almost always exactly what you need right out of the box
Seth Madore
