Milling path: how to avoid round interior corner
olivier58SHD
olivier58SHD
When the milling path is computed,  it takes into account the diameter of the tool.
This cause interior corners to be rounded and not sharp.
Some CNC programs have an option to force the corner to be sharp even if that remove more material.
Is that possible with fusion360 ?
HughesTooling
No, Fusion does not have this option. You'd need to model it the way you want it.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
There is a bogbone add in here that might help with your designs.
Mark
Mark Hughes
