Fusion Manufacture
Milling a slot
10 REPLIES 10
Message 1 of 11
miengineer313
235 Views, 10 Replies
Milling a slot
Hello!
I have a 5 1/2" x 3/4" slot with 1/8" corner radius that id like to mill with two different size endmills. A 1/2" flat endmill to cut the bulk of material, then a 1/4" flat end mill to come in and clean up the walls and get the 1/8"R corners. Im having trouble getting the 1/4" endmill to only clean up the walls. I am attaching a picture for clarity.
10 REPLIES 10
Message 2 of 11
engineguy
in reply to: miengineer313
@miengineer313
Are you looking for something like the image below, if so try the attached file, may help 🙂 🙂
Message 3 of 11
miengineer313
in reply to: engineguy
That helped a ton! Changing the bottom height to "selected contours" changed everything. Anyway you could explain that so I know for future use? I usually just select "stock top" then enter the height in a negative value to get the tool to the depth I need.
Message 4 of 11
miengineer313
Also in your simulation it shows the stock as a solid piece. I cannot seem to get that on mine, any suggestions?
Message 5 of 11
engineguy
@miengineer313
I used the Selected Contours as that is usually the best option for doing something like this, it is in my opinion more specific and accurate.
You should get a solid stock if you uncheck the Transparent option as in the image below. Hope this gives you a bit more clarity 🙂 🙂
Message 6 of 11
miengineer313
Gotcha! I might do it that way from now on.
As far as the transparency, when I start my simulation the slot is already gone. It doesn't show the material being machined. It just shows the toolpath.
see attached 🙂
Message 7 of 11
engineguy
@miengineer313
In your image you have the Transparancy checked so you need to uncheck it, also your image doesn`t show what you have the Opacity set to, if that slider is all the way to the Left then what you will get is as shown below.
Message 8 of 11
miengineer313
I tried tampering with the settings, still cant seem to get it 😕 I took another screenshot, looks like my settings are pretty similar to yours.
I appreciate all the help!
Message 9 of 11
seth.madore
It doesn't look like you ever shared your Fusion file. I suspect what you're seeing is because your Stock is the same as your Model, but that's just a guess. Could you share your actual Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 10 of 11
miengineer313
in reply to: seth.madore
You were correct! I changed the stock option from "from solid" to "relative size box" with no additional stock and it worked. Greatly appreciated!
Message 11 of 11
engineguy
@miengineer313
That would be correct, I had to create a file to show as a example, always best if you can upload your Fusion f3d file 🙂 🙂 🙂
