Fusion Manufacture
mill an arc only on the end of stock
2 REPLIES 2
burnandreturn
134 Views, 2 Replies
I need to mill an arc or radius on the end of 40x40mm steel.  I would like to mount the material in the vise with the end sticking out the side of the vise.  Then just mill a radius on the end with a 20mm radius so the end of the material has a half circle radius on it.   I have tried to select just the half circle arc but it won't let me just mill the arc.  frame ends.jpg
2 REPLIES 2
seth.madore
in reply to: burnandreturn
Press the ALT key and select the arc 🙂
Seth Madore
Thank you.  That worked a treat!
