Fusion Manufacture
Messy Wrapped toolpath
3 REPLIES 3
CallumTSVQX
121 Views, 3 Replies
Im trying to use a lathe with C-axis milling to produce a wrapped feature around the Z axis. However the cycle is very messy and not smooth.
Anyone got any ideas on how to tidy up the unwanted plunges and the stat stop motion as it spins in C, I did think about using the rotary function but it doesn't seem to want to play ball either.
https://a360.co/3TgRKMb
Machine is a Doosan Lynx LM if it matters
 Callum
3 REPLIES 3
seth.madore
in reply to: CallumTSVQX
That file doesn't seem to have any Wrap Contours on it. Could you share a file that DOES have such a toolpath? If it's easier, you can export and share the Fusion .f3d file here instead of the A360 link
Seth Madore
CallumTSVQX
in reply to: seth.madore
I Seem to have it running how I wanted as a slot, however id like to offset it and use the side of the cutter opposed to the middle, any ideas?
CallumTSVQX
Ignore me, ive got the 2d contour to run it. I was being thick.
