Fusion Manufacture
Mazak QT-EZ8MSY Sub features not matching Main features
3 REPLIES 3
mike.belloni
97 Views, 3 Replies
I'm having issues getting features machined on the sub spindle to line up correctly with features done on the main. I'm drilling 3 holes through Z of the part on the main, transferring to the sub and counterboring the remaining length of the hole with an endmill. The counterbores done on the sub are shifted 30 degrees from the holes drilled on the main. I'm using Mazatrol in the post (G53.5) and below is the transfer code for the part. New to this machine but I feel like I'm missing something obvious.
(SUBSPINDLE GRAB1)
M5
G53 B0.
G53 X0. Y0.
G53 Z0.
M1
T1212.01
G0 G98 Z0 (CLEAR)
M901
M200 (C1 AXIS ON)
G0 C0. (MAIN ANGLE)
M202 (C1 AXIS OFF)
M902
M300 (C2 AXIS ON)
G110 C2 (CROSS AXIS CONTROL)
G0 C0. (SUB ANGLE)
G111 (CROSS AXIS CONTROL CANCEL)
M302 (C2 AXIS OFF)
M901
M306 (UNCLAMP SUB CHUCK)
G4 U1
M540 (TRANSFER MODE ON)
G0 B[#501-10 (MOVE HD2 TO APPROACH)
G1 B[#501-16.3234] F40.
M307 (CLAMP SUB CHUCK)
G4 U1
(SUBSPINDLE RETURN1)
M206 (UNCLAMP MAIN CHUCK)
G4 U1
M541 (TRANSFER MODE CANCEL)
G0 G53 B0. (SUB SPINDLE RETURN)
G99
M513 (SYNCHRONIZATION OFF)
M305 (SUB SPINDLE STOP)
M5
G0 G53 B0.
G53 X0. Y0.
G53 Z0.
M30
3 REPLIES 3
a.laasW8M6T
in reply to: mike.belloni
I'm not familiar with Mazaks(yet) but I notice in the post there is an option for phase or speed sync
I imagine this needs to be set to phase?
It looks like your code is being output correct.
do you have an offset in your Sub or main C axis in the WCS page of the mazatrol?
mike.belloni
in reply to: a.laasW8M6T
It is indeed set to phase. There is a main C-offset for the G53.5 WCS.
a.laasW8M6T
So would the offset value in G53.5 be accounting for the error?
I'll have to go and look at my friends QT200MSY on Friday and see what they do
