Fusion Manufacture
Mazak qt does not have g81 or g83 canned drill cycle
3 REPLIES 3
simonswb6
459 Views, 3 Replies
I have a older lathe, Mazak qt18 with a tplus control that does not have the canned pecking drill cycle or canned drill cycle, G83 and G81 respectively .  Would it be possible to modify the post to convert a g83/g81 to just g0/g1?  how would i go about doing this and a possible code example?
-------------------------------example ------------------------------------
Original g83
( Drill1 )
G17
M3 S1000
G0 X-9.5
G98
G83 X-9.5 Z-5.0 R0.2 Q0.1 F200.0
Modified G83 code.
( Drill1 )
G17
M3 S1000
G0 X-9.5
G1 Z-3.0 F200
G1 Z0.0
G1 Z-6.0 F200
G1 Z0.0
G1 Z-9.0 F200
G1 Z0.0
G1 Z-12.0 F200
G1 Z3.0 F1200
3 REPLIES 3
Ketherton21
in reply to: simonswb6
have you tried other post processors?
you could just write a mazatrol program for your drilling, and then stick in a subprogram for everything else. one thing I always loved about Mazatrol.
might be something in the parameters in your controller, since mazatrol has a peck1/peck2 option.
@simonswb6
you can do this by expanding the cycle
if you edit the post you get to see codes like this case "deep-drilling"
      break;
    case "deep-drilling":
      var tz = cycle.incrementalDepth;
      var k0 = cycle.retract - cycle.stock;
      // d0 not supported
      if (cycle.dwell > 0) { // not supported by cycle
        expandCyclePoint(x, y, z);
      } else {
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
          getCommonCycle(x, y, z, cycle.retract),
          "Q" + xyzFormat.format(tz),
          feedOutput.format(F),
          conditional(k0 > 0, "K" + xyzFormat.format(k0))
      break;
    case "tapping":
instead you can modify the post something like below to post in the expanding mode
      break;
      break;
    case "tapping":
Save the post and test it carefully
Boopathi Sivakumar
Senior Technology Consultant
jason.hahn716
Another practice is to set a dwelling time, once its value is greater than zero, it'll expand cycle point.
