Mazak post - need to move smoothing (G5 P2) below lengthcompensation (G43) ----- Help!
will263RT
will263RT
Im using the generic Mazak post for our VCN 570c.  In order for smoothing to work it (G5 P2) must be called after the G43 line.  I have move the  setSmoothing(smoothing.isAllowed); line to every line I could think of and received either an error or no change in return.  I'm sure this is  a simple fix and it would be so nice not to have to modify each post manually for this.
Thank you for your support!!
Arun.rs
HI @will263RT
Thanks for raising your concern via Forum.
Open 'Mazak.cps' file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Go to line number 1222 , cut the line ' setSmoothing(smoothing.isAllowed);
2. Paste the code at line number 1275 ie, after '
validate(lengthCompensationActive, "Length compensation is not active."); '
3. Go to line number 762, put '//' just before '
validate(!lengthCompensationActive, "Length compensation is active while trying to update smoothing.");
Save the file and test the post carefully.
Regards
If my post answers your question, please click the 'Accept Solution' button. This helps everyone find answers more quickly!
Arun.RS
Senior Technology Consultant
