Fusion Manufacture
Mazak HCN-6000 CCW rotary indexing
2 REPLIES 2
dandersonF79KU
92 Views, 2 Replies
Hi all,
I have a Mazak HCN-6000 that I'm posting programs using a modified version of the generic Mazak milling post (v44104), and have a slight nuisance I was hoping somebody may have a solution for.
The indexing rotary on this machine uses 1x1000 degrees for the rotary units, which I've been able to modify the post for; but this machine indexes in the clockwise direction by default, unless an M42 command is given with the rotary position. Example: rotating from 270° to 260° would index in the clockwise direction all the way around, without the M42 code.
Is there any way to modify the post to get the previous op's rotary position, compare to the position to be indexed; and then if the difference is negative add M42 before the rotary position to force counter-clockwise indexing?
Thanks in advance!
2 REPLIES 2
Hi @dandersonF79KU
let's suppose you want to implement this functionnality in the inLinear5D function
It is possible to interrogate the previous value of an output variable before we set something different inside.
function onLinear5D(_x, _y, _z, _a, _b, _c, feed, feedMode) {
  if (!currentSection.isOptimizedForMachine()) {
    error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath."));
    return;
  // at least one axis is required
  if (pendingRadiusCompensation >= 0) {
    error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
    return;
  var oldCValue = cOutput.getCurrent();
  if (_c >= oldCValue) {
    writeln("Growing");
  } else {
    writeln("Diminishing");
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  var a = aOutput.format(_a);
  var b = bOutput.format(_b);
  var c = cOutput.format(_c);
In my example, line 11 I am grabbing the value of the axis, before it is updated in line 22.
Both value, the _c and the oldCvalue will be expressed as radian unit, not degree.
My initial test is very simple, and assume that both values will be positive.
In fact we should compare the values in three differents scenarios.
Both values positives, both negative, and the mix one positive, the other negative, to implement a more reliable check.
Ax you may have to use it in different location in the post, it will probably be better to create a function isCRotationCW, and passing the old and new values to the function.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Thanks Serge! I'll give this a try the next time I post for this machine.
