Fusion Manufacture
mazak generic milling
6 REPLIES 6
tillettslawncare
175 Views, 6 Replies
I am having troubles editing the post processor, I need would like to alter/change some things in my post. I need it to add a % at the very top of the program before the O# (program number) and after the m30 (program end) Also I would like to move my G49 line to my G30 G91 Z 0. Y 0. so it is cancelled in a move. Lastly I need to take out all my heighth and diameter compensation, I am using my mazatroll tool data so I do not need to use H and D codes. I am currently editing my post (code) in notepad to get the results but would like to have the post spit out what i need. Thank you in advance .
Reid
6 REPLIES 6
Give this a try. I've removed the D and H calls, as well as a "%" at the beginning and end. I've not yet touched the location of the G49, that will have to wait until I have some time later or someone else comes along and offers some time.
TEST CAREFULLY!
Seth Madore
Thank you for the help I have figured out how to manipulate all but the tool change should look like this T001T01M6   T001 tool in spindle T01 next tool to machine.
Thanks in advance, Reid
Does it not run okay the way it is, or is this a matter of wanting it to "look" a certain way?
Seth Madore
It’s the way my Mazak calls up tools I believe it has to be that way when using mazatrol tool data. I could be wrong though.
Nvm, it works with the tool call that way thanks so much for the help! Now I can post with no editing.
reid
Hi @seth.madore,
One thing to be aware. You need to have a Z axis approach after a G53 Z move and before G5 P2 or you will crash the machine.
T12 T27 M6 ( T12: CAB_O25HF_Z3 )
S3000 M3
G90 G94 G17
G55
M132 (AR PELO CENTRO)
G0 X45.937 Y-56.171
Z27. <- FIRST Z MOVE BEFORE HIGH-SPEED. LENGTH COMPENSATION ACTIVE
G61.1
G5 P2 <- HIGH-SPEED MODE
G0 Z5.
G1 Z1.4 F7000.
X-45.937
X-56.904
G2 Y-44.961 I0. J5.605
S3000 M3
G90 G94 G17
G55
G0 X45.937 Y-56.171
G61.1
Z27. <- FIRST Z MOVEMENT AFTER HIGH-SPEED ON. NO LENGTH COMPENSATION. WILL CRASH
G0 Z5.
G1 Z1.4 F7000.
X-45.937
X-56.904
Regarding the tool call, I answered my own post (another one) through the weekend.
It works fine with the stock post:
T01 M6
T02
The benefit of using T01 T02 M6 is when editing a program we have a function called Quick EIA:
Where I put an arrow, you can move quickly between tool calls inside the program by simply pressing on the list.
But you need to have the current and next tool called on the same line, or it will create a call for the current tool and another one for the next tool.
