Fusion Manufacture
May22 update - dialogue box unit increment arrows removed
11 REPLIES 11
Message 1 of 12
iporter6
651 Views, 11 Replies
Firstly, I just want to say thanks to the Fusion team for another update to a truly great product.  I use it every day for multi axis milling, turning and part design.
Anyway, Please can you put back the unit increment arrows in the operation dialogue boxes?  I use them all the time as they worked really well.  It was intelligently adaptive to the number of decimal places.
p.s The 3 dots options in the update are great additions.
many thanks
11 REPLIES 11
Message 2 of 12
jeff.pek
in reply to: iporter6
Hi -
This was done intentionally to synch up with prior changes in other areas of Fusion, as a result of adding the 3-dot menu. I'll raise your request with our Experience Design folks -- maybe they can think up a compromise, especially if this is something that a lot of users find helpful. Tell your friends to speak up if so!
Jeff
Message 3 of 12
Don.Cyr
in reply to: jeff.pek
@jeff.pek
+1 for me as well. This was also discussed in the CAB chat.. seems like for certain  dialogs this is definitely a feature that is missed.
Please click "Accept Solution" if I helped with your question or issue.
Message 4 of 12
mattdlr89
in reply to: Don.Cyr
Same here, didn't realise I actually used them until they were gone. I'd like to see them back especially for any integer fields.
Message 5 of 12
a.laasW8M6T
Yes, I use these arrow all the time and now have to select the value with the mouse then edit with the keyboard which is adding time to my programming.
Mostly use this in the bottom height field if I want my tool to go 1mm below the model bottom for instance I just click on the arrow once.
Message 6 of 12
I use this too! Exactly like @a.laasW8M6T says.
I do think this needs to be brought back. In my opinion it would not interfer with the 3dot menu
Message 7 of 12
timwilliames
This is honestly such a great feature that has been removed and I agree with @Anonymous said. Please either bring this back or make it an option to turn on and off in preferences.
Message 8 of 12
iporter6
@jeff.pek I just want to make sure this topic doesn't fall off the table.  Any feed back on bringing it back?
Message 9 of 12
jeff.pek
I haven't seen anything more on this here internally. I've nudged our experience designers to try to get an update.
  Jeff
Message 10 of 12
leighCB8FK
Please add this back in.
Message 11 of 12
gtprototype
Rant On: There seems to be an unstoppable effort to make the software GUI cleaner at the expense of usability.  The scroll bars are so narrow they've all but disappeared.  Remember when you could grab an edge of a dialog box and increase the width or height to suit your needs?  Now with everything hidden it requires exponentially more mouse clicks to accomplish most things.  The font sizes are small with less contrast to increase eye strain, but hey, you didn't buy it to use it did you.  It's so pretty, why would you clutter it up to make it useable? Rant Off
Dale Speakes
prototype technology
Message 12 of 12
a.laasW8M6T
I still want these arrows back, it really reduces programming efficiency.
More mouse clicks + physical hand movement = more time to achieve what used to be one simple click
Same with the new chaining methods, lots more wasted movement and additional clicks(I know there has been some improvements in this area that are yet to be released but...)
