Fusion Manufacture
Marking hole location with plasma
2 REPLIES 2
sebbecx
557 Views, 2 Replies
Is there any way to use the plasma operations to mark a hole location in fusion? With that i mean move to hole location before lighting the arc for a few milliseconds thus making a small crater? I know this is possible with for example sheetcam but havent figures out how to do so in fusion. I have tried to do so with a drill operation but my postprocessor does not suppport it.
Thanks in advance
Sebastian
2 REPLIES 2
belstain
in reply to: sebbecx
Unfortunately there's no great way to do this.  But there are workarounds that aren't too bad once it's all set up.
What I did is create a Favorited dimension to use on simple pierced holes. Mine is .200" diameter. So whenever I want a marked center I just make the hole in my design (or a sketch overlay) that size. Then I created a Tool with the plasma kerf set to a couple thou under the hole size. Then I saved a toolpath with no lead in/out as a Template so I can quickly just pick the .200" hole or sketch circle  and not ever need to mess with any of those settings again. This gives a toolpath that pierces then moves in a .002" circle, so basically just a point.
Because plasma toolpaths have no Lead To Center option I also created templates for common hole sizes with lead ins that start approximately in the center of the hole. So for example I have templates for holes 3/16, 1/4, 5/16, 3/8. Each has its own lead in that gets the pierce point near center. I have another for holes bigger than half inch but still too small to use my normal lead in/out templates.
gmcnuttHCF6S
in reply to: belstain
could you share your tool setup?  I am trying to get accurate placement of holes
