March 2024 Post Processor and Machine Simulation What's New
andrea.amilo
Community Manager Community Manager
Message 1 of 1
andrea.amilo
Post Processor and Machine Simulation What’s New
Looking for the latest post processors and machines updates? Look no further!
We are continually working hard to bring you updates and improvements to the many open-source Post Processors and Machines we offer for free, but those updates often get lost in the shuffle of other enhancements or big feature releases. This post aims to update you on newly added or improved post processors and machines, so you can stay up to date on what you use today or look for news so you can get the most out of Fusion.
This post will get refreshed with notable updates as they’re released, and you can click each hyperlink to go to the mentioned post. As always, you can find the latest in our post processor offering on the Online Post Library where you can search by vendor, type, or name, and see any recent changes to each post processor.
MAIN CONTENTS
  1. Improved Post Processors
  2. New Machines
  3. New Workholdings
  4. Improved Workholdings
  5. Post Processor Engine
  6. Post Processor Ideas
We are always working to keep post processors up to date with new technologies. This is a summary of the main improvements made to post processors already in the library.
Generic Post Processors
milling.pngAdded support for 'First Pass' cycle parameter usage inside turning threading operations in multiple generic post processors.
Milling Post Processors
Doosan 3/5-axis VMC
Rebranding of postprocessor name from Doosan to DN Solutions.
Heidenhain, Heidenhain iTNC 426, Heidenhain Inspection, Kern
-Fixed prepositioning for head kinematics in multiple Heidenhain post processors.
-Fixed TCH PROBE 425 cycle in the Heidenhain based post processors.
-Added mandatory quotes to string declaration in the Heidenhain Inspection post processor.
-Solved issue when using property 'singleResultsFile' in the Heidenhain Inspection post processors.
-Property 'resultsFileLocation' now sets the correct file location in the Heidenhain Inspection post processors.
-Fixed output syntax of variable Q330 in probing cycles when property 'toolAsName' is enabled but the tool description is empty.
Kern Micro
Turning Post Processors
Doosan Turning
Mill-Turn Post Processors
Doosan Mill/Turn
Haas CL-1, Haas DS-30Y, Haas DS-30SSY, Haas ST-10, Haas ST-15, Haas ST-20, Haas ST-25, Haas ST-28, Haas ST-30, Haas ST-35, Haas ST-40, Haas ST-45, Haas ST-55, Haas ST-10L, Haas ST-15L, Haas ST-20L, Haas ST-25L, Haas ST-28L, Haas ST-30L, Haas ST-35L, Haas ST-40L, Haas ST-45L, Haas ST-10Y, Haas ST-15Y, Haas ST-20Y, Haas ST-25Y, Haas ST-28Y, Haas ST-30Y, Haas ST-35Y, Haas ST-10LY, Haas ST-15LY, Haas ST-20LY, Haas ST-25LY, Haas ST-28LY, Haas ST-30LY, Haas ST-35LY, Haas ST-20SS, Haas ST-20SSY, Haas ST-30SS, Haas ST-30SSY, Haas Turning
Updated the Haas mill-turn post processors to the latest version.
2. New Machines
Machine Library
The Machine Library lets you manage your machine tools by using Machine Configurations to define your available machines and resources. These configurations can automate the settings in your Job Setup.
There are many Machine Configurations available in the standard library.
You will have available configuration files for some of the leading machine manufacturers:
Photon Ultra
Photon X
Photon Zero
Photon Mono SE
Photon Mono SQ
Photon Mono X
DNM 4000
DVF 5000
DVF 8000
Malachite
The easiest way to get started, is to copy an existing configuration that matches some of the characteristics of your machine.
3. New Workholdings
Workholding Library
The Workholding library lets you add a workholding equipment (vise, table, tombstone, etc.) to a manufacturing model. Those can be found in the "CAM Samples" project folder that you can find in the Fusion data panel:
7 Fixture Plates
2 Pallets
7 Pins & Jacks
6 Vice Files
Updated 26 Lang Vices.
Updated 52 Mate Vices.
6. Post Processor Engine
Our development team is always working to update and fix the Autodesk CAM Post Processor engine. These modifications are not related to a specific postprocessor (as described above) but affect the entire library or at least the post processors using that specific class. The current post processor kernel is 4.6050.1, soon to be 4.6084.
API.pngAdded the onFeedMode function which is called whenever the feedrate mode changes during an operation.
API.pngAdded the activeFeedMode variable and corresponding getActiveFeedMode function which contain/return the active feedrate mode.
You can find here all the information regarding the Autodesk CAM Post Processor engine.
To make our library more varied and complete, we are always working on new post processors. Some of them still need more testing before being released in the public library. Every new Beta post processor is announced in the Idea Station, you can find all of them in the Post Processor Idea Station.
Please note that if you choose to use one of these post processors, you assume all inherent risk in using it and we ask that you proceed with caution.
That being said, we are looking forward to get your feedback!
Click here to see the previous What’s New release.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Replies (0)
