Fusion Manufacture
Manufacturing two parts that are the same diameter are ending up with different circumferences
2 REPLIES 2
psychochook
90 Views, 2 Replies
I have created 2 parts that are to be used as a mold for plastic injection machine.  Both of the parts consist of a circle 100mm across.
I generated tool paths and exported them to use with my CNC machine.  After milling the parts, one of them is 99.5mm across and the other is 102.4mm.  I have tried milling the molds twice and the diameters are the same so that indicates that it is the code that is the issue.
One of the molds is using 3d contour as a finishing pass on the mold (as it has a gutter with fillets around the perimeter of the mold) and the tool is a 1.75mm ball end mill.  The other mold has 3d flat as the finishing pass and a 4mm end mill.  I thought that maybe one of them had "Tool center on boundary" for Tool Containment but they are both set to "Tool inside boundary".
Can anyone suggest why I am getting different results when I mill these two parts?
2 REPLIES 2
seth.madore
in reply to: psychochook
What is your machine and controller? Neither of those toolpaths would be my first choice for finishing something that could be handled much better with, for example, a 2D Contour toolpath using Cutter Compensation.
Seth Madore
psychochook
in reply to: seth.madore
I have a QB2 with nighthawk controller - https://www.cnc3d.com.au/qb2-cnc-1000x1500mm
I am still fairly new to Fusion360.  I will have a look at Cutter Compensation and creating tool paths with 2d contour to see how that looks.
Thanks for the suggestion.
