Manufacturing T-splines
kulpio
kulpio
Hi!
I am modeling a body kit that will be machined on foam. I will model it in form environment, close in patch and convert to a body.
Will the body from a t-spline be an issue to generate toolpaths?
what type of advice would you have while modeling to have in mind to end up with a simple and clean toolpath at the end?
Thank you!
jeffescott
Use minimum number of points
let fusion set smooth curve then make small changes with the control handles
