Manufacture - Multi-Axis
Teddy.limGSQVN
Community Visitor
Teddy.limGSQVN
Community Visitor
Community Visitor
There seems to be a bug in the "Reverse" in the multi-axis conture
The direction of the Green and Red arrow cannot reverse??
https://acontrolsg-my.sharepoint.com/:u:/g/personal/teddy_lim_a-control_com_sg/EW0bhaRlvNFLrJ0m5VR0Q...
Please advise
seth.madore
The green and red arrow in your image are your WCS alignments. If you need to move those around, you should use Tool Orientation
Seth Madore
DarthBane55
It could also be the start/end arrows, and he wants to reverse the start and end.  That would be done using climb vs conventional under the passes tab.  Not sure what OP really wants to reverse.
The reverse on OP picture is for 2d operations, but it is showing up here because of the standardized form I think, there is no red arrow to reverse in 3d ops (would mill in the part instead of outside of the part, but 3d ops are model aware and know which side to cut).
Teddy.limGSQVN
Community Visitor
Community Visitor
Hi All,
Thank you very much for the solution provided, we managed to solve the problem by removing the entry position that we accidentally set last time.
