Manual NC Action with keyword 'usepolarmode'.
philipp.meissner
philipp.meissner
Dear All,
wishing everyone a merry christmas! :slightly_smiling_face:
I am stuck and can´t figure out how to "force G112 mode for a specific operation by using Manual NC Action with keyword 'usepolarmode'."
I am using this post processor: https://cam.autodesk.com/posts/post.php?name=haas%20st-15
In description it is saying:
Preconfigured HAAS ST-15 post with support for mill-turn. You can force G112 mode for a specific operation by using Manual NC Action with keyword 'usepolarmode'.
I tried to do this several times, googled a lot, tried and tried, but never got anything working.
Can anyone please guide me through how to do this?
Thanks!
Marco.Takx
Hi @philipp.meissner,
I did a quick check and get it to work without any problem.
I created a mill operation (2D Contour) and placed before that operation a Manual NC (Action) with the text"usepolarmode"
See attachment.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
philipp.meissner
Dear Marco,
thanks a lot!
I am unsure if this is the solution because:
- This operation will use G112 polarmode even with your manual NC disabled.
- I intend to use this for radial milling. I tried using the manual NC as per your example.
This did not work.
I never found a way to make this work and I am afraid, this is not possible.
Marco.Takx
The sample that I sent you is working for axial milling not radial.
If you suppress the Manual NC the G112 is gone and unsuppress the Manual NC it gives you an output with G112.
Marco Takx
ed
Running into the same problem.  I have a manual NC set to action and have tried:
'usepolarmode'
"usepolarmode"
usepolarmode
anyone have any ideas?
ed
Did not have it checked in the list of operations in the post dialog.  Working now.
