Fusion Manufacture
making a flat pattern of half of elbow
8 REPLIES 8
Message 1 of 9
tim.gsmachine
229 Views, 8 Replies
I have drawn half of a 4" elbow and i want to make a flat pattern of it so that the blank can be laser cut and formed in a press. I cant figure out how to figure out the shape of a flat blank. please help
8 REPLIES 8
Message 2 of 9
Can you export the design as an f3d and share here? If not can you create something similar to share.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
Mark
Thanks for the reply. We just finished another project for the same customer using titanium but it was a round to oval transition cone however they supplied the blank for us to laser cut. This is another project but we are having trouble determining a flat pattern. fusion file attached
thanks in advance
Message 4 of 9
Mark
Further to this we are only looking to develop halve of the elbow as it will be welded in two pieces
Message 5 of 9
I don't think you can do this in Fusion because it's curved in 2 directions so needs to be unwrapped. You can extract a surface and export as an STL then use MeshMixer to Unwrap it. See attached SVG exported from MeshMixer. Looks like you need to scale the svg by 1.3333 to get the correct size.
Mark Hughes
Message 6 of 9
Mark
That's awesome, greatly appreciate the help one this. How did you know you had to scale it by 1.3333?
Message 7 of 9
@tim.gsmachine wrote:
Mark
There are a few threads about the problem with scaling SVG imports. It seems like Fusion's default is 96dpi but exports from Illustrator are 72dpi so the scaling in 96/72. Odd thing is MeshMixer was created by AutoDesk so Fusion and MeshMixer using different defaults seems a bit odd!
Mark Hughes
Message 8 of 9
seth.madore
in reply to: HughesTooling
This looks like a thread that would be better served in the Design forum, do you agree? (I can move it if it's better off living in that forum)
Seth Madore
Message 9 of 9
Mark
Again thanks a lot for the help.
