Fusion Manufacture
Make Grove same width as Diameter of Endmill
4 REPLIES 4
arendVisher
112 Views, 4 Replies
I am trying to cut a grove or Dato. I want to use a Flat endmill that is the same width as the grove.
When I try using 2D Contour It won't create a tool path.
If I use grove that is wider than the diameter of the endmill it will create the tool path, with multiple passes.
Am I using the correct tool path for this operation?
4 REPLIES 4
arendVisher
in reply to: arendVisher
I also tried using 2D pocket.  Same result.
MichaelD872
Have you tried selecting only one line of the open pockets you are trying to machine?
You might want to splitt the operations into 2 operations so that your tool does not gauge your part at one of your pockets that ends in a wall.
I have attached a little program for you to see what i mean.
You could also link your own program if you would like someone to help you with the problem directly
arendVisher
in reply to: MichaelD872
What is the best way to link the project?
MichaelD872
Just Export the file and save it somewhere on your PC and drag the file into the drop zone in the chat.
