Fusion Manufacture
Maho MH 700 C TNC 310 Postprocessor
3 REPLIES 3
Heizmann4RWLG
275 Views, 3 Replies
I am currently trying to get my milling machine running with Fusion 360.
I already found out, that i can use the TNC 407 postprocessor.
But my spindle does use the Y-Axis instead of the Z-Axis.
I saw older tips, where you could change the postprocessor settings to "vertical", but this option isn´t given in the current version.
Can somebody help me, what i have to do, to change the axis?
Thanks in Advance!
Lukas
3 REPLIES 3
in reply to: Heizmann4RWLG
Hi!
Can you share the post processor?
sfyris_c
Hello to All,
Have you managed to find a solution about this?
I'm having exactly the same issue here with a MAHO 700 and Heidenhain TNC 310.
Just please note that its also necessary to reverse the replaced axis (-Z = +Y and vice versa).
Kind Regards
Christos
