Fusion Manufacture
Machining Undercut
6 REPLIES 6
weber_dominic
200 Views, 6 Replies
Machining Undercut
Hopefully someone can help me
I'm trying to machine an undercut with a 2mm Ball Endmill.
I'v tried Contour and Steep and Shallow like in the Tutorial, but for some reason i can't get it to work.
Does anyone know what i'm doing wrong and can point me in the right direction?
6 REPLIES 6
a.laasW8M6T
in reply to: weber_dominic
Hi
For steep and shallow you need to select Steep only and then the machine undercuts checkbox appears
Turning on collision avoidance from point gets contour to work too
I have attached the file with Blend, Flow and Geodesic as examples too
Have a look through the settings to see how it is achieved
seth.madore
Could I interest you in a really nice looking Geodesic?
I'm puzzled why the Contour didn't hit the undercut, it's normally rather good at that. Admittedly, I've not yet tried it in multi-axis mode, so there may be an issue that needs to be investigated. Ah well, another task for me tomorrow 🙂
Seth Madore
seth.madore
in reply to: a.laasW8M6T
@a.laasW8M6T thanks for reminding me about the Collision Avoidance requirement for Contour!
-EDIT-
But, it doesn't appear that your version has any better luck getting into the corner 🤔
Seth Madore
a.laasW8M6T
@seth.madore , I just assumed it was due to the multi axis-ing haha, I didn't look closely I now recall that Contour can only do undercuts in 3 axis I'm pretty sure
EDIT: It seems to work in 5 axis with a lollipop, not sure why it wont with a ballnose
Thank you both for your help! I did it for now with Steep and Shallow, will look into Geodesic more in future! Didn't really use that so far.
Thanks again!
seth.madore
Just a nice thing to look forward to; we've done some work in this area and a future release should see the ability for Contour to handle undercuts when in 5 axis mode 😁
Seth Madore
