Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Machining Undercut using 45 degree Dovetail
2 REPLIES 2
kboreo
150 Views, 2 Replies
I have a part I am trying to machine a undercut using a 45 degree dovetail cutter with the steep and shallow toolpath.
I was using the Autodesk steep and shallow tutorial.  (https://help.autodesk.com/view/fusion360/ENU/courses/AP-STEEP-SHALLOW-3X-UNDERCUT)  All I did was duplicate the tool path that worked and then just switched the tool to a dovetail cutter, but the toolpath is not milling everything like it was with the lollipop cutter.  Is it possible to machine a undercut with a dovetail cutter?
I attached the Fusion 360 file along with 2 screenshots showing the tool path.
Here is a screenshot of how the toolpath originally looked in the tutorial:
Here is the same toolpath with only the tool changed:
Please let me know if you need anymore
2 REPLIES 2
a.laasW8M6T
in reply to: kboreo
The problem lies with how the tool has been defined in the tool library.
I'm guessing you used a standard tool but extended the length?
increasing the shoulder length is incorrect, it must remain the same as the flute length
 and then the length on the shaft page should be made longer
then it generates correctly
kboreo
in reply to: a.laasW8M6T
You are 100% correct, that is exactly what I did trying to prove undercuts out before it got to our programmer.
Your recommended changes worked perfectly!
Thanks!
Technology Administrators
