Fusion Manufacture
Machining slopes goes only halfway and doesnt recognize everything
5 REPLIES 5
mike_vos
133 Views, 5 Replies
I want to machines some slopes in fusion but there are some problems:
1. it doesnt recognizes alle slopes, only the 'big' ones.
2. the slopes it does recognize aren't  machined all the way down to the bottom of the model.
What can i change?
Thanks in advance
5 REPLIES 5
seth.madore
in reply to: mike_vos
Can you share your file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
mike_vos
Here is the file
oleg.tikhomirov
Hi @mike_vos
Please change the following setting:
Oleg Tikhomirov
Software Engineer
seth.madore
@oleg.tikhomirov thanks for chiming in! (it's been a busy morning and this thread fell by the wayside)
@mike_vos When you have it set to "Tool Center on Boundary", you end up being constrained the closer that the boundaries are to each other. On the left side of the part, where the slope is more gradual, it doesn't influence the result a whole lot. On the right side, however, you end up with boundaries that are quite close together, which either greatly reduce or outright eliminate the toolpath:
Setting it to "Outside" gives the toolpath permission to machine to the extent that you're expecting.
One other possible solution is to not use Boundaries and just use "Touch" surfaces:
Seth Madore
mike_vos
Thank you! this solution worked
